# JavaScript Scripting
This add-on provides support for JavaScript (ECMAScript 2021+) that can be used as a scripting language within automation rules.
This add-on includes by default the openhab-js (opens new window) NPM library and exports it's namespaces onto the global namespace. This allows the use of items, actions, cache and other objects without the need to explicitly import using require(). This functionality can be disabled for users who prefer to manage their own imports via the add-on configuration options.
# UI Based Rules
Advanced users, or users migrating scripts from existing systems may want to use File Based Rules for managing rules using files in the user configuration directory.
# Adding Triggers
Using the openHAB UI, first create a new rule and set a trigger condition
# Adding Actions
Select "Add Action" and then select "ECMAScript 262 Edition 11". Its important this is "Edition 11" or higher, earlier versions will not work. This will bring up a empty script editor where you can enter your javascript.
You can now write rules using standard ES6 Javascript along with the included openHAB standard library.
items.getItem("KitchenLight").sendCommand("ON");
console.log("Kitchen Light State", items.getItem("KitchenLight").state);
Sending a notification
actions.NotificationAction.sendNotification("[email protected]", "Balcony door is open");
const thingStatusInfo = actions.Things.getThingStatusInfo("zwave:serial_zstick:512");
console.log("Thing status",thingStatusInfo.getStatus());
See openhab-js (opens new window) for a complete list of functionality
# Scripting Basics
The openHAB JSScripting runtime attempts to provide a familiar environment to Javascript developers.
# Require
Scripts may include standard NPM based libraries by using CommonJS require. The library search path will look in automation/js/node_modules in the user configuration directory.
# Console
The JSScripting binding supports the standard console object for logging.
Script debug logging is enabled by default at the TRACE level, but can be configured using the console logging commands.
log:set DEBUG org.openhab.automation.script
console.log(obj1 [, obj2, ..., objN])console.info(obj1 [, obj2, ..., objN])console.warn(obj1 [, obj2, ..., objN])console.error(obj1 [, obj2, ..., objN])console.debug(obj1 [, obj2, ..., objN])console.trace(obj1 [, obj2, ..., objN])
where obj1 ... objN is a list of JavaScript objects to output. The string representations of each of these objects are appended together in the order listed and output.
see https://developer.mozilla.org/en-US/docs/Web/API/console (opens new window) for more information about console logging.
# setTimeout
The global setTimeout() method sets a timer which executes a function or specified piece of code once the timer expires.
var timeoutID = setTimeout(function[, delay, arg1, arg2, ...]);
var timeoutID = setTimeout(function[, delay]);
The global clearTimeout() method cancels a timeout previously established by calling setTimeout().
see https://developer.mozilla.org/en-US/docs/Web/API/setTimeout (opens new window) for more information about setTimeout.
# setInterval
The setInterval() method repeatedly calls a function or executes a code snippet, with a fixed time delay between each call.
var intervalID = setInterval(func, [delay, arg1, arg2, ...]);
var intervalID = setInterval(function[, delay]);
The global clearInterval() method cancels a timed, repeating action which was previously established by a call to setInterval().
NOTE: Timers will not be canceled if a script is deleted or modified, it is up to the user to manage timers. See using the cache namespace as well as ScriptLoaded and ScriptUnLoaded for a convenient way of managing persisted objects, such as timers between reloads or deletions of scripts.
see https://developer.mozilla.org/en-US/docs/Web/API/setInterval (opens new window) for more information about setInterval.
# ScriptLoaded
For file based scripts, this function will be called if found when the script is loaded.
scriptLoaded = function () {
console.log("script loaded");
loadedDate = Date.now();
# ScriptUnLoaded
For file based scripts, this function will be called if found when the script is unloaded.
scriptUnloaded = function () {
console.log("script unloaded");
//clean up rouge timers
clearInterval(timer);
# Paths
For file based rules, scripts will be loaded from automation/js in the user configuration directory.
# Standard Library
Full documentation for the openHAB JavaScript library can be found at openhab-js (opens new window)
The items namespace allows interactions with openHAB items.
See openhab-js : items (opens new window) for full API documentation
- items :
object- .getItem(name, nullIfMissing) ⇒
Item - .getItemsByTag(...tagNames) ⇒
Array.<Item> - .createItem(itemName, [itemType], [category], [groups], [label], [tags], [giBaseType], [groupFunction], [itemMetadata])
- .addItem(itemName, [itemType], [category], [groups], [label], [tags], [giBaseType], [groupFunction])
- .removeItem(itemOrItemName) ⇒
Boolean - .replaceItem(itemName, [itemType], [category], [groups], [label], [tags], [giBaseType], [groupFunction])
- .safeItemName(s) ⇒
String
const item = items.getItem("KitchenLight");
Calling getItem(...) returns an Item object with the following properties:
- Item :
object- .type ⇒
String - .name ⇒
String - .label ⇒
String - .history ⇒
ItemHistory - .state ⇒
String - .rawState ⇒
HostState - .members ⇒
Array.<Item> - .descendents ⇒
Array.<Item> - .isUninitialized ⇒
Boolean - .tags ⇒
Array.<String> - .getMetadataValue(namespace) ⇒
String - .updateMetadataValue(namespace, value) ⇒
String - .upsertMetadataValue(namespace, value) ⇒
Boolean - .updateMetadataValues(namespaceToValues)
- .sendCommand(value)
- .sendCommandIfDifferent(value) ⇒
Boolean - .postUpdate(value)
- .addGroups(...groupNamesOrItems)
- .removeGroups(...groupNamesOrItems)
- .addTags(...tagNames)
- .removeTags(...tagNames)
- .type ⇒
//send a ON command
item.sendCommand("ON");
//Post an update
item.postUpdate("OFF");
//Get state
console.log("KitchenLight state", item.state)
calling item.history... returns a ItemHistory object with the following functions:
Note serviceId is optional, if omitted, the default persistance service will be used.
- ItemHistory :
object- .averageSince(timestamp, serviceId) ⇒
Number - .changedSince(timestamp, serviceId) ⇒
Number - .deltaSince(timestamp, serviceId) ⇒
Number - .deviationSince(timestamp, serviceId) ⇒
Number - .evolutionRate(timestamp, serviceId) ⇒
Number - .historicState(timestamp, serviceId) ⇒
state - .lastUpdate(serviceId) ⇒
Date - .latestState(serviceId) ⇒
state - .maximumSince(timestamp,serviceId) ⇒
state - .minimumSince(timestamp,serviceId) ⇒
state - .persist(serviceId)
- .previousState(skipEqual,serviceId) ⇒
state - .sumSince(timestamp, serviceId) ⇒
Number - .updatedSince(timestamp, serviceId) ⇒
Boolean - .varianceSince(timestamp,serviceId) ⇒
state
var item = items.getItem("KitchenDimmer");
console.log("KitchenDimmer averageSince", item.history.averageSince(yesterday));
The actions namespace allows interactions with openHAB actions. The following are a list of standard actions.
Additional actions provided by user installed addons can be accessed using their common name on the actions name space
(example: actions.Pushsafer.pushsafer(...))
# Audio Actions
See openhab-js : actions.Audio (opens new window) for complete documentation
# BusEvent
See openhab-js : actions.BusEvent (opens new window) for complete documentation
# Ephemeris Actions
See openhab-js : actions.Ephemeris (opens new window) for complete documentation
Ephemeris is a way to determine what type of day today or a number of days before or after today is. For example, a way to determine if today is a weekend, a bank holiday, someone’s birthday, trash day, etc.
Additional information can be found on the Ephemeris Actions Docs (opens new window) as well as the Ephemeris JavaDoc (opens new window).
// Example
let weekend = actions.Ephemeris.isWeekend();
# Exec Actions
See openhab-js : actions.Exec (opens new window) for complete documentation
Execute a command line.
// Execute command line.
let Duration = Java.type('java.time.Duration');
actions.Exec.executeCommandLine(Duration.ofSeconds(20), 'echo', 'Hello World!');
// Get response from command line.
let response = actions.Exec.executeCommandLine('echo', 'Hello World!');
response = actions.Exec.executeCommandLine(Duration.ofSeconds(20), 'echo', 'Hello World!');
# HTTP Actions
See openhab-js : actions.HTTP (opens new window) for complete documentation
// Example GET Request
# ScriptExecution Actions
See openhab-js : actions.ScriptExecution (opens new window) for complete documentation
let now = time.ZonedDateTime.now();
function timerOver () {
logger.info('The timer is over.');
// Create the Timer.
this.myTimer = actions.ScriptExecution.createTimer(now.plusSeconds(10), timerOver);
// Cancel the timer.
this.myTimer.cancel();
let active = this.myTimer.isActive();
// Reschedule the timer.
this.myTimer.reschedule(now.plusSeconds(5));
# Semantics Actions
See openhab-js : actions.Semantics (opens new window) for complete documentation
# Things Actions
See openhab-js : actions.Things (opens new window) for complete documentation
# Voice Actions
See openhab-js : actions.Voice (opens new window) for complete documentation
# Cloud Notification Actions
(optional action if openhab-cloud is installed)
Notification actions may be placed in Rules to send alerts to mobile devices registered with an openHAB Cloud instance (opens new window) such as myopenHAB.org (opens new window).
For available actions have a look at the Cloud Notification Actions Docs (opens new window).
// Example
actions.NotificationAction.sendNotification('<email>', '<message>'); // to a single myopenHAB user identified by e-mail
actions.NotificationAction.sendBroadcastNotification('<message>'); // to all myopenHAB users
Replace <email> with the e-mail address of the user.
Replace <message> with the notification text.
# Cache
The cache namespace provides a default cache that can be use to set and retrieve objects that will be persisted between reloads of scripts.
See openhab-js : cache (opens new window) for full API documentation
- cache :
object- .get(key, defaultSupplier) ⇒
Object | null - .put(key, value) ⇒
Previous Object | null - .remove(key) ⇒
The defaultSupplier provided function will return a default value if a specified key is not already associated with a value
let counter = cache.get("counter", () => ({ "times": 0 }));
console.log("Count",counter.times++);
Example (Get a previously set object)
let counter = cache.get("counter");
if(counter == null){
counter = {times: 0};
cache.put("counter", counter);
# Log
By default the JS Scripting binding supports console logging like console.log() and console.debug() to the openHAB
default log. Additionally scripts may create their own native openHAB logs using the log namespace
let logger = log('my_logger');
//prints "Hello World!"
logger.debug("Hello {}!", "world");
# Time
openHAB internally makes extensive use of the java.time package. openHAB-JS exports the excellent JS-Joda library via the time namespace, which is a native Javascript port of the same API standard used in Java for java.time. Anywhere that a native Java ZonedDateTime or Duration is required, the runtime will automatically convert a JS-Joda ZonedDateTime or Duration to its Java counterpart.
var item = items.getItem("Kitchen");
console.log("averageSince", item.history.averageSince(yesterday));
See JS-Joda for more examples and complete API usage.
# File Based Rules
The JSScripting binding will load scripts from automation/js in the user configuration directory. The system will automatically reload scripts when changes are detected to files. Local variable state is not persisted among reloads, see using the cache for a connivent way to persist objects.
File based rules can be created in 2 different ways: using JSRule or the Rule Builder.
See openhab-js : rules (opens new window) for full API documentation
# JSRule
JSRules provides a simple, declarative syntax for defining rules that will be executed based on a trigger condition
const email = "[email protected]"
rules.JSRule({
execute: data => {
triggers.ChannelEventTrigger('astro:sun:local:rise#event', 'START')
triggers.ItemStateChangeTrigger('my_item', 'OFF', 'ON')
triggers.ItemStateUpdateTrigger('my_item', 'OFF')
triggers.ItemCommandTrigger('my_item', 'OFF')
triggers.GroupStateChangeTrigger('my_group', 'OFF', 'ON')
triggers.GroupStateUpdateTrigger('my_group', 'OFF')
triggers.GroupCommandTrigger('my_group', 'OFF')
triggers.ThingStatusUpdateTrigger('some:thing:uuid','OFFLINE')
triggers.ThingStatusChangeTrigger('some:thing:uuid','ONLINE','OFFLINE')
triggers.SystemStartlevelTrigger(40) //Rules loaded
triggers.SystemStartlevelTrigger(50) //Rule engine started
triggers.SystemStartlevelTrigger(70) //User interfaces started
triggers.SystemStartlevelTrigger(80) //Things initialized
triggers.SystemStartlevelTrigger(100) //Startup Complete
triggers.GenericCronTrigger('0 30 16 * * ? *')
triggers.TimeOfDayTrigger('19:00')
# Rule Builder
Rules are started by calling rules.when() and can chain together triggers,
conditions and operations in the following pattern:
rules.when().triggerType()...if().conditionType().then().operationType()...build(name,description);
Rule are completed by calling .build(name,description) , if name or description are omitted, a generated value will be used.
rules.when().item("F1_Light").changed().then().send("changed").toItem("F2_Light").build("My Rule", "My First Rule");
console.log(event);
see Examples for further patterns
# Rule Builder Triggers
when()or().channel(channelName)Specifies a channel event as a source for the rule to fire..triggered(event)Trigger on a specific event name
.cron(cronExpression)Specifies a cron schedule for the rule to fire..item(itemName)Specifies an item as the source of changes to trigger a rule..for(duration).from(state).to(state).fromOff().toOn().receivedCommand().receivedUpdate()
.memberOf(groupName).for(duration).from(state).to(state).fromOff().toOn().receivedCommand().receivedUpdate()
.system().ruleEngineStarted().rulesLoaded().startupComplete().thingsInitialized().userInterfacesStarted().startLevel(level)
.thing(thingName)changed()updated()from(state)to(state)
Additionally all the above triggers have the following functions:
.if()or.if(fn)-> a rule condition.then()or.then(fn)-> a rule operation.or()-> a rule trigger (chain additional triggers)
# Rule Builder Conditions
if(optionalFunction).stateOfItem(state)
# Rule Builder Operations
then(optionalFunction).build(name, description).copyAndSendState().copyState().inGroup(groupName).postIt().postUpdate(state).send(command).sendIt().sendOff().sendOn().sendToggle()
# Rule Builder Examples
//Basic rule, when the BedroomLight1 is changed, run a custom function
}.build();
//turn on the kitchen light at SUNSET
rules.when().timeOfDay("SUNSET").then().sendOn().toItem("KitchenLight").build("Sunset Rule","turn on the kitchen light
at SUNSET");
//turn off the kitchen light at 9PM
rules.when().cron("0 0 21 * * ?").then().sendOff().toItem("KitchenLight").build("9PM Rule", "turn off the kitchen light
at 9PM");
//set the colour of the hall light to pink at 9PM
rules.when().cron("0 0 21 * * ?").then().send("300,100,100").toItem("HallLight").build("Pink Rule", "set the colour of
the hall light to pink at 9PM");
//when the switch S1 status changes to ON, then turn on the HallLight
rules.when().item('S1').changed().toOn().then(sendOn().toItem('HallLight')).build("S1 Rule");
//when the HallLight colour changes pink, if the function fn returns true, then toggle the state of the OutsideLight
rules.when().item('HallLight').changed().to("300,100,100").if(fn).then().sendToggle().toItem('OutsideLight').build();
//and some rules which can be toggled by the items created in the 'gRules' Group:
//when the HallLight receives a command, send the same command to the KitchenLight
rules.when().item('HallLight').receivedCommand().then().sendIt().toItem('KitchenLight').build("Hall Light", "");
//when the HallLight is updated to ON, make sure that BedroomLight1 is set to the same state as the BedroomLight2
rules.when().item('HallLight').receivedUpdate().then().copyState().fromItem('BedroomLight1').toItem('BedroomLight2').build();
