Runtime Commands
Examples
Query an item's state:
Changing an item's state:
Get help for a command:
Items
| Command | Description |
openhab:status <item> | shows the current status of an item |
openhab:update <item> <state> | sends a status update for an item |
openhab:send <item> <command> | sends a command for an item |
openhab:items list [<pattern>] | lists names and types of all items (matching the pattern, if given) |
openhab:items clear | removes all items |
openhab:items remove <itemName> | removes the given item |
Discovery
openhab:discovery start <thingTypeUID!bindingID> | runs a discovery on a given thing type or binding |
openhab:discovery enableBackgroundDiscovery <PID> | enables background discovery for the discovery service with the given PID |
openhab:discovery disableBackgroundDiscovery <PID> | disables background discovery for the discovery service with the given PID |
Inbox
openhab:inbox | lists all current inbox entries |
openhab:inbox listignored | lists all ignored inbox entries |
openhab:inbox approve <thingUID> <label> | creates a thing for an inbox entry |
openhab:inbox clear | clears all current inbox entries |
openhab:inbox ignore <thingUID> | ignores an inbox entry permanently |
Things
openhab:things list | lists all things |
openhab:things clear | removes all managed things |
Links
openhab:links list | lists all links |
openhab:links link <itemName> <channelUID> | links an item with to channel |
openhab:links unlink <itemName> <thingUID> | unlinks an item with to channel |
openhab:links clear | removes all managed links |
openhab:links orphan <list|purge> | lists/purges all orphaned - one missing element (either item or channel) - links |
Audio
openhab:audio play [<sink>] <filename> | plays a sound file from the $OPENHAB_CONF/sounds folder through the optionally specified audio sink(s) |
openhab:audio play <sink> <filename> <volume> | plays a sound file from the $OPENHAB_CONF/sounds folder through the specified audio sink(s) with the specified volume |
openhab:audio stream [<sink>] <url> | streams the sound from the url through the optionally specified audio sink(s) |
openhab:audio sources | lists the audio sources |
openhab:audio sinks | lists the audio sinks |
Voice
openhab:voice say <text> | speaks a text on the default audio sink with the default TTS and voice |
openhab:voice voices | lists available voices of the active TTS services |
openhab:voice interpret <command> | interprets a human language command |
Automation
openhab:script <script to execute> | Executes a script from the $OPENHAB_CONF/scripts folder |
Firmware
openhab:firmware list <thingTypeUID> | Lists the available firmwares for a thing type. |
openhab:firmware status <thingUID> | lists the firmware status for a thing |
openhab:firmware update <thingUID> <firmware version> | updates the firmware for a thing |
Users
openhab:users list | lists all users |
openhab:users add <userId> <password> <role> | adds a new user with the specified role |
openhab:users remove <userId> | removes the given user |
openhab:users changePassword <userId> <newPassword> | changes the password of a user |
openhab:users listApiTokens | lists the API tokens for all users |
openhab:users addApiToken <userId> <tokenName> <scope> | adds a new API token on behalf of the specified user for the specified scope |
openhab:users rmApiToken <userId> <tokenName> | removes (revokes) the specified API token |
openhab:users clearSessions <userId> | clear the refresh tokens associated with the user (will sign the user out of all sessions) |
