# openHAB on Linux
If you find yourself in a situation, where you have no write access to the openHAB configuration or system files wrong permissions and/or the incorrect use of sudo are often the cause.
# Meeting the Requirements
If you're unsure which manual file you should download, using dpkg --print-architecture or rpm -q --qf '%{ARCH}\n' rpm in your Linux terminal should point you in the right direction (e.g. armhf means ARM Hard Float).
Make sure to download Zulu or Java 11.
# Installation
- manually from file.
# openHABian project
# Apt Based Systems
First, add the openHAB repository key to your package manager:
wget -qO - 'https://openhab.jfrog.io/artifactory/api/gpg/key/public' | sudo apt-key add -
- Stable Release - The stable builds contain the latest official release with tested features. - Add the openHAB Stable Repository to your systems apt sources list: - echo 'deb https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main' | sudo tee /etc/apt/sources.list.d/openhab.list
- Testing Release - The beta and release candidate builds come out less frequently, but will contain new features that are currently in the testing phase. - Add the openHAB Beta Repository to your systems apt sources list: - echo 'deb https://openhab.jfrog.io/artifactory/openhab-linuxpkg testing main' | sudo tee /etc/apt/sources.list.d/openhab.list
- Snapshot Release - The snapshot build is created almost daily (opens new window), and include the latest changes to the openHAB core and add-ons. These changes are often unstable, so you should use this branch only for testing or development purposes. - The snapshot repository is hosted in openHAB's JFrog Artifactory instance (opens new window). To use it, add the openHAB Unstable Repository to your systems apt sources list: - echo 'deb https://openhab.jfrog.io/artifactory/openhab-linuxpkg unstable main' | sudo tee /etc/apt/sources.list.d/openhab.list
sudo apt-get update
sudo apt-get install openhab
# Yum or Dnf Based Systems
The RPM repo information should be defined inside a file, make a new file at /etc/yum.repos.d/openhab.repo with the following contents depending on your choice of release.
You may add all three to the same file, but make sure the desired repo is is set to enabled=1:
- Stable Release - The stable builds contain the latest official release with tested features. - [openHAB-Stable] name=openHAB Stable baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/stable gpgcheck=1 gpgkey="https://openhab.jfrog.io/artifactory/api/gpg/key/public" enabled=1
- Testing Release - The beta or release candidate builds come out less frequently, but will contain new features that are currently in the testing phase. - [openHAB-Testing] name=openHAB Testing baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/testing gpgcheck=1 gpgkey=https://openhab.jfrog.io/artifactory/api/gpg/key/public enabled=1
- Snapshot Release - The snapshot build is created almost daily (opens new window), and include the latest changes to the openHAB core and add-ons. These changes are often unstable, so you should use this branch only for testing or development purposes. - [openHAB-Snapshots] name=openHAB Snapshots baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/unstable gpgcheck=1 gpgkey=https://openhab.jfrog.io/artifactory/api/gpg/key/public enabled=1
sudo yum install openhab
# Arch Linux
cd openhab3
makepkg -s
sudo systemctl daemon-reload
You should be able to reach the openHAB Dashboard at http://openhab-device:8080 at this point.
If you're new to openHAB, then you should checkout the beginner's tutorial!
# Service Control
sudo /etc/init.d/openhab stop
After installing openHAB, a shortcut named openhab-cli provides access to the openHAB-specific commands (such as backup, restore, and console).
To use the shortcuts in a terminal, simply type openhab-cli followed by the command.
For example:
Usage:  openhab-cli command [options]
Possible commands:
  start [--debug]     -- Starts openHAB in the terminal.
  stop                -- Stops any running instance of openHAB.
  status              -- Checks to see if openHAB is running.
  console             -- Opens the openHAB console.
  backup [filename]   -- Stores the current configuration of openHAB.
  restore filename    -- Restores the openHAB configuration from a backup.
  showlogs            -- Displays the log messages of openHAB.
  info                -- Displays distribution information.
# Changing Versions
# Apt Based Systems
Upgrading is as easy as:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get update
apt-cache showpkg openhab
sudo yum upgrade
rpm -q openhab
# Uninstall
# Apt Based Systems
sudo apt-get purge openhab*
sudo yum remove openhab*
# Manual Installation
We are going to download a platform independent archive file and extract it to the path /opt/openhab.
As openHAB is still in an evolving state, the snapshot may be the preferred choice.
- Official Release - Download and extract the latest offical stable version of openHAB from our downloadpage (opens new window) to your host: - cd /tmp wget -O openhab-download.zip https://www.openhab.org/download/releases... # Insert download link here sudo unzip openhab-download.zip -d /opt/openhab rm openhab-download.zip
- Beta/RC Release - If available, beta or release candidate builds of openHAB can also be downloaded from our downloadpage (opens new window) and extracted to your host as shown above.
- Snapshot Release - Download and extract the latest snapshot version of openHAB from our downloadpage (opens new window) to your host. The process is analogue to above.
The extracted openHAB files should belong to the earlier created openhab user.
Execute:
Everything is ready for a first test run.
Execute openHAB and you should be able to reach the openHAB Dashboard at http://openhab-device:8080 after a few minutes:
# Service
The service will be running with the privileges of the user "openhab" and expects the openHAB files under /opt/openhab.
[Unit]
Wants=network-online.target
After=network-online.target
[Service]
User=openhab
Group=openhab
WorkingDirectory=/opt/openhab
Restart=on-failure
SuccessExitStatus=0 143
[Install]
WantedBy=multi-user.target
#start and retrieve status
# Installing add-ons
Simply download the kar files (the latest builds can be found here (opens new window)) and move them to the /opt/openhab/addons folder.
# Upgrade
- Versions 2.1.0 and Above - From version 2.1.0, openHAB is distributed with the update script included. This script should be called from within openHAB's root directory. Assuming the openHAB directory is in - /opt/openhab, simply run the following commands to update to the next major version of openHAB:- cd /opt/openhab sudo runtime/bin/update- You can also specify any version as a parameter. For example, to switch back to 2.0.0: - sudo runtime/bin/update 2.0.0- You may also change to openHAB's more frequent, but less stable snapshot builds. Just append "-SNAPSHOT" to the target version, e.g.: - sudo runtime/bin/update 2.2.0-SNAPSHOT
- Older Versions - If you're using a version earlier than 2.1.0, then you can use the following commands in Terminal to download the script and run it. Assuming the openHAB directory is in - /opt/openhab:- cd /opt/openhab sudo sh -c "$(curl -fsSL https://raw.githubusercontent.com/openhab/openhab-distro/main/distributions/openhab/src/main/resources/bin/update)" -- 2.1.0
# Uninstall
sudo rm -rf /opt/openhab/
# File Locations
| Repository Installation | Manual Installation (according to guide) | |
| openHAB application | /usr/share/openhab | /opt/openhab |
| Additional add-on files | /usr/share/openhab/addons | /opt/openhab/addons |
| Site configuration | /etc/openhab | /opt/openhab/conf |
| Log files | /var/log/openhab | /opt/openhab/userdata/logs |
| Userdata like rrd4j databases | /var/lib/openhab | /opt/openhab/userdata |
| Backups folder | /var/lib/openhab/backups | /opt/openhab/backups |
| Service configuration | /etc/default/openhab | (not preconfigured) |
# Backup and Restore
To make a backup of openHAB 2 or higher, you need to retain your configuration and userdata files.
openHAB comes with scripts for storing your configuration in a zip file which is saved in /var/lib/openhab/backups for automatic installs and openhab/backups for manual installs.
## OR ##
# Viewing Log Messages
- Package repository based installation: - tail -f /var/log/openhab/openhab.log -f /var/log/openhab/events.log
- Manual installation: - tail -f /opt/openhab/userdata/logs/openhab.log -f /opt/openhab/userdata/logs/events.log
The following example shows how to add Linux user openhab to the often needed groups dialout and tty.
sudo adduser openhab dialout
sudo adduser openhab tty
sudo adduser openhab audio
# Java Network Permissions
# Network Sharing
sudo vim /etc/samba/smb.conf
wins support = yes
- Package repository based installation: - [openHAB-userdata] comment=openHAB userdata path=/var/lib/openhab browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777 [openHAB-conf] comment=openHAB site configuration path=/etc/openhab browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777 [openHAB-logs] comment=openHAB logs path=/var/log/openhab browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777
- Manual installation: - [openHAB-files] comment=openHAB path=/opt/openhab browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777
sudo smbpasswd -a openhab
samba-tool testparm
sudo service smbd restart
# Mounting Locally
- On macOS: Open Finder → Go → Connect to Server: smb://[email protected]
- On Windows: Open Windows Explorer → Address bar: \\openhab-device.local→ Right click a share and assign a drive letter
Be sure to use the actual host name instead of openhab-device.
If you are not able to connect, try with the IP of your device (e.g. smb://[email protected] or \\192.168.0.2).
