# Android App
The openHAB Android application is a native client for openHAB, compatible with phones and tablets. The app follows the basic principles of the other openHAB UIs, like Basic UI, and presents your predefined openHAB sitemap(s) (opens new window).
# Getting Started
This will only work on local networks and when the server does not enforce either authentication or HTTPS.
If it fails, you can click on Go to settings
and manually enter the server settings.
- IP address:
http://192.168.1.3:8080
- Local hostname:
http://openhab:8080
(depending on your network the suffix.local
needs to be added to the hostname) - Remote domain name:
https://myopenhab.org
for an openHAB cloud account with myopenHAB (opens new window)
# Features
- Change items via NFC tags
# Permanent Deployment
If you want to use openHAB Android on a wall mounted tablet, go to settings and select Disable display timer
and Fullscreen
This prefixes every item name, e.g. with the Prefix John
the item AlarmClock
becomes JohnAlarmClock
# Alarm Clock
Example item definition:
Example rule:
var Timer timerAlarm = null
rule "Alarm Clock"
Item AlarmClock changed or
System started
if (!(AlarmClock.state instanceof DateTimeType)) {
return;
val alarmTime = AlarmClock.state as DateTimeType
logInfo("alarm", "Scheduling alarm for {}", alarmTime.toString)
if (timerAlarm !== null) {
logInfo("alarm", "Rescheduling alarm")
timerAlarm.reschedule(alarmTime.getZonedDateTime)
logInfo("alarm", "New alarm")
timerAlarm = createTimer(alarmTime.getZonedDateTime.minusSeconds(5), [ |
logInfo("alarm", "Alarm expired")
timerAlarm = null
# Call State
Example rule:
rule "Call State"
Item CallState changed
// No call activity
# Battery Level
Example rule:
rule "Battery level"
Item BatteryLevel changed
// Battery level is low
# Charging State
The charging state can be send to a String
Item that contains the charger type or to a Switch
Item, which is ON
when charging, OFF
otherwise.
// or
Example rule for the String
Item:
rule "Charging state"
Item ChargingState changed
# Wi-Fi Name (SSID)
Example rule:
rule "Wi-Fi name"
Item WifiName changed
# DND Mode
Example rule:
rule "DND mode"
Item DndMode changed
// DND mode is unknown
# Gadgetbridge Device Actions
Example rule:
rule "Gadgetbridge"
Item Gadgetbridge changed
# Device identifier
<Device identifier>|
- Prefix the item names of Send device information to openHAB
- Use it as state on NFC tags
# Tasker Action Plugin
The variable %httpcode
is returned by the plugin and contains the HTTP code returned by the server.
Error Code | Description |
10 | Tasker plugin is disabled |
11 | The app couldn't establish a connection |
1000+ | A connection was established, but an error occurred. The error code is 1000 + the HTTP code, e.g. 1401 means Unauthenticated (opens new window). |
# Multi server support
- Quick tiles
- NFC tags
- Push notifications
- Tasker plugin
# Help and Technical Details
# My voice command rule isn't run
Please make sure that Default Human Language Interpreter
is set to Rule-based Interpreter
(http://openhab:8080/#!/settings/services/org.openhab.voice (opens new window)) and that the correct Item is selected at Other Services
=> Rule Voice Interpreter
=> Voice Command Item
(http://openhab:8080/#!/settings/services/org.openhab.rulehli/select/ (opens new window)).
# Chart loading is too slow
If you experience slow chart loading times and your server isn't powerful, open Settings
and disable High resolution charts
to improve loading times.
# Icons look pixelated
# Trademark Disclaimer
