# Tips and Tricks
# Backups
When installed on Linux there will be an openhab-cli command line tool that supports backup and restore.
For other systems, under $OH_HOME/runtime/bin you will find backup.sh and restore.sh (or .bat).
# Don't Wait, Try it Out!
# Developer Sidebar
Note that the sidebar will not come up if your display is to narrow. It will not work on a phone nor on most tablet displays.
There are four tabs on the sidebar.
# Pinned Objects
Let's say you are working on your lighting automations which involves Things, Items, and Rules. Instead of keeping a dozen browser tabs open and flipping between them you can pin these objects to the sidebar. In the search box at the top, enter a search term which can be part of an object's name, ID, label, etc.
Once you've pinned all the objects you want, click the x icon in the search bar.
# Event Monitor
The list is OR meaning is any one matches the event will be shown.
For example, entering *Hum* would only show those events that include "Hum" in the names.
# Code Tools
# Expression Tester
# Scratchpad
# Create Shortcuts
# Save Examples
# Where's it all Being Saved?
Everything presented in this tutorial is "managed" and saved to a text based JSON formatted database in $OH_USERDATA/jsondb.
# API
# Asking for Help
- provide lots of details
- be polite.
