# Preface
# OpenHAB Configuration Files
  • via mounting the files shares from the server to your client-PC. In the main UI as an admin you can go to Help & About and will have the different folder locations under Technical information.
  • Use the share openHAB-conf when mounting it from Windows or MacOS
  • Find you openHAB-Server via the network share functionality
  • User the share openHAB-conf to assign it to a network drive
  • Finder -> Go -> Connect to Server
    • Enter the username and server name to connect to the openHAB Server
    • then choose the folder you want to mount
    macos-share-2
Finding it on Linux
  • Access the folder directly on the openHAB server at /etc/openhab
  • html
  • icons
  • items
  • services
  • html
  • persistence
  • rules
  • scripts
  • sitemaps
  • sounds
  • things
  • transform
  • go to Settings -> Rules
  • press plus on bottom right
  • enter a unique id and rule name for your new blockly rule
  • Under "When" click on "Add Trigger" to define a trigger for the rule (you may add multiple triggers which are perceived as any of those triggers may occurs which stands for an OR combination of the triggers)
    • choose a title for the rule
    • choose "item" (or something else) that should trigger the rule
    • select the item from your model and the click PICK on the upper right corner
    • choose "received a command", "was updated" or "changed"
  • Under "Then" click on "Add Action"
  • choose run-script-1
  • click on run-script-2 und you should now see this screen blockly-edit-screen
  • you can now click the toolbox-submenu to access all openHAB Blocks.
  • Drag and Drop the blocks to the white area
  • Press Ctrl-s (Windows) or Command-s (MacOS) to save your rule
  • Press Ctrl-r (Windows) or Command-r (MacOS) to directly run your rule with the trigger
  • Press Ctrl-d (Windows) or Command-d (MacOS) to disable / enable your rule
  • Click on showcode on the lower right to see the generated code (click again to come back to the blocks)
