# Persistence
# Persistence Blocks
- average: gets the average value of the State of a persisted Item since a certain point in time. This method uses a time-weighted average calculation
- delta: gets the difference in value of the State of a given Item since a certain point in time
- deviation: gets the standard deviation of the state of the given Item since a certain point in time
- variance: gets the variance of the state of the given item since a certain point in time
- evolution rate: gets the evolution rate of the state of the given Item in percent since a certain point in time (may be positive or negative)
- minimum: gets the minimum value of the State of the given Item since a certain point in time
- maximum: gets the maximum value of the State of the given Item since a certain point in time
- maximum: gets the sum of the State of the given Item since a certain point in time
Note: in case no or 0 values are retrieved, make sure that the item in question is actually persisted.
Function: checks if an item was updated or changed since a certain point in time
Type: boolean true or false
