- Calling Rules or other scripts either located as files on the server or provided via the UI
- Retrieving attributes provided by the rule context or from the own caller rule.
- Transforming values via different conversion methods (map, regex, jsonpath)
# Overview of the Run & Process blocks
# Run & Process Blocks
# Call Script File
- No parameters can be provided
See openHAB Call-Script (opens new window) for background information
# Run Rule or Script created in UI
The ruleUID can be found in the list of rules or scripts in the second line of the list (like here helloBlockly or helloWorld)
Parameters are optional:
- If not providing parameters leave the with context section as is.
- If providing parameters you must replace the create empty dictionary block with the dictionary block from the Lists section (opens new window), modifying the number of key/value pairs to suit.
Notes:
- parameters can be retrieved in the called script via the "get context attribute"-block (see below)
- the called rule / script cannot return any value
- it is not possible to access a particular function in another script or rule as scripts / rules have to be perceived as completely autonomous
- the called rule / script is run synchronously
# Retrieve context attribute from rule
# Retrieve rule context information
- The rule trigger type defines which of the attributes are available to the rule - they will not all be available.
- For more detailed information see Event Object Attributes (opens new window) or openHAB Events (opens new window).
# Transform values via Map, Regex or JsonPath and others
OpenHAB provides many transformations (opens new window):
- Map (opens new window)
- Regex (opens new window)
- JsonPath (opens new window)
- Binary to Json (opens new window)
- Exec (opens new window)
- JavaScript (opens new window)
- Jinja (opens new window)
- Scale (opens new window)
- XPath (opens new window)
- XSLT (opens new window)
# Example 1: Regex
# Example 2: JsonPath transformation
by using the jsonpath
$.device.status.temperature
# Example 3: Map transformation
ON=Ja
OFF=Nein
effects=Effekte
NULL=n/a
hs = Hue/Saturation
ct = Color Temperature
Hue/Saturation
# Inline Script
# Example:
