# Colors
colors-overview
# Color Picker
color-picker
# Random Color
get-random-color
# Create RGB color
create-rgb-color
# Blend two colors
blend-two-colors
Tip: this could be used for example with a loop that changes the ratio from 0 to 1 to blend the first color into a second
get-hsb-of
  • use that block and connect one of the above blocks into that one to be able to retrieve the HSB value of that block.
get-hsb-of-example
# Lists
lists-overview
dictionary
dictionary-example
dictionary-getkey
dictionary-getkey-example
