# Colors
# Color Picker
# Random Color
# Create RGB color
# Blend two colors
Tip: this could be used for example with a loop that changes the ratio from 0 to 1 to blend the first color into a second
- use that block and connect one of the above blocks into that one to be able to retrieve the HSB value of that block.
# Lists
