# Overview
The different guides of this chapter assume that you are somewhat familiar with Java 11 and that you have a rough understanding of Git's workflow (e.g. "checkout", "branches", "push").
# Choose the Right Concept
- Bindings: A binding connects to external services or devices.
- Automation engine module: A trigger, condition, or action that can be used in automation rules (or scripts).
- Transformation / Profiles: Can be used to transform a Thing Channel- value before it is assigned to an Item.
- An IO service: Exposes openHAB internals via a defined interface (for example the REST interface, HomeKit or Hue Emulation Service).
- A Persistence service: Persist item state updates and/or changes and allows them to be retrieved for specific points in time.
- Natural language processing skill: Executes something depending on the understood Intents and returns something back to the user.
- Audio sinks/sources: Control where audio can be played or implement audio sources.
- and many more (not covered yet).
Development can happen on any of the supported operating systems (Windows, macOS, Linux).
- Git (opens new window) For retrieving our source code and push changes back. On Windows: Must be available in %PATH%
- Maven 3.x (opens new window) Our buildsystem tool. On Windows: Must be available in %PATH%
- Java JDK 11, for example from Oracle Oracle JDK 11 (opens new window). On Windows: %JAVA% must be set.
# Develop a NEW binding
To help start developing a new binding, a script is available to generate the basic skeleton for you. This script is specific for binding addons. Follow these steps to generate your binding:
From the command line in
openhab-addons/bundlesdirectory to create a skeleton of a new bindingmynewbindingrun:On Linux:
./create_openhab_binding_skeleton.sh MyNewBinding "<Author>" <GitHubUsername>On Windows:
create_openhab_binding_skeleton.cmd MyNewBinding "<Author>" <GitHubUsername>Add your binding to the
bundles/pom.xmlfileUse your full name for
<Author>.Accept with
Ywhen the skeleton configuration asks for it.From
openhab-addonsroot you can build only your binding with Maven using the-ploption:mvn clean install -pl :org.openhab.binding.mynewbindingWhere
mynewbindingis the name of your new binding. Some additional Maven options that may help:-U: Forces all dependencies to be downloaded again.-am: Builds all projects in openhab-addons your project dependends on.-o: Won't update any dependencies.-DskipChecks: Skips the static analysis checks-DskipTests: Skips the unit tests-Dspotless.check.skip=true: Skips the spotless file formatting checks-Dohc.version=3.0.2: The version of openhab you are building for
To start your new binding it's a good practise to commit your code on a new git branch:
git checkout -b <mynewbranch>Open Eclipse or your favorite editor and import your new binding project
If developing on Windows, git will convert line endings from LF to CRLF automatically. The repo uses LF,
and spotless will object, and throw errors. If you use mvn spotless:apply to fix formatting, it will add CRLF
to all files dirtying the entire branch. Adding a .gitattributes file to the openhab-addons folder with the
following will tell git and spotless to use LF endings:
* text eol=lf
