# Blockly Reference
One of the core feature that OpenHAB provides is writing rules to allow specific behaviour with the home automation system. The usual way of developing rules is by coding them like described in the Textual Rules. However, this art of programming may become intimidating early on and shy away away people with few or almost no experience in programming. Therefore openHAB also provides a graphical way of writing rules which allows to put together rules in a rather visual way (even though some programming background may still help).
The basic idea behind the visual paradigm and representation within openHAB is based on the Google Blockly Support (opens new window) which has been integrated and which provides the basic blocks for programming like the ones on the left and the right side of the below images
Blockly toolbox
All of these provide general functionality that is not specific to openHAB itself. If you want to learn more about how to use them, search for the many blockly tutorials that are available. However, to leverage the full capabilities more than 50 specific blocks have been provided that are tailored for easy access of openHAB's capabilities.
This section provides a detailed description of the specific blocks and provides examples on how to use them. Note that some of the blocks (like voice, streaming or notifications) need some special setup within openHAB - in these case links to the respective documentation is provided. It should also be mentioned that each of the blocks do have a context sensitive menu which appears upon a right click on the block itself.
Block context menu
Looking for help
A special mention should go towards the Help entry that links to a resource that is usually very helpful to understand the context of that particular block. Please read this information first before asking questions in the forum. In case you ask for help please always post the respective code that is being generated.
# Before using blockly
Please visit Getting started with openHAB Blocklies before asking questions in the forum
# Blocks
# Items and Things
Items and Things are the major entities of openHAB (opens new window) to control and monitor the home.
See Items & Things section
# Timers and Delays
Timers and Delays are a little more complex but add important functionality to rules. Whilst the “Wait-For”-block is straightforward, the timer blocks should be well understood before being used - they may behave differently than expected. This chapter explains what these blocks do, sometimes displaying generated code to explain what is happening behind the scenes.
See Timers and Delays section.
# Date Handling
Date blocks are used as input parameters for other blocks. At the moment some of these blocks are found in the ephemeris section, whilst others are found in the persistence section - they may be equally useful for both. These blocks are typed to assure correct connection to other blocks.
See Date Handling section.
# Ephemeris
The ephemeris category provides blocks with calendar functionality. The blocks can be used to determine what type of day today is, or a number of days before or after today is. For example, a way to determine if today is a weekend, a bank holiday, someone’s birthday, trash day, etc.
See Ephemeris section.
# Voice and Multimedia
This section deals with playing or streaming audio to an audio sink e.g a speaker or saying a text via using any Text-to-Speech API (e.g. Google's API)
See Voice and Multimedia section.
# Notifications
For use with your openHAB cloud (opens new window) account, these blocks can be used to send notifications to relevant connected devices. Notifications can be used as push message to devices running the openHAB client.
See Notifications section.
# Persistence
Persistence blocks enable access of historical data stored by the default persistence service.
See Persistence section.
# Value Storage
These blocks enable storing information for a rule that is kept after the rule has run, so it can be reused when the rule is run again later in stateful way.
See Value Storage section.
This section allows calling rules or other scripts, retrieving attributes provided by the rule context or transforming values via different conversion methods (e.g. map, regex, jsonpath)
See Run and Process section.
# Logging
See Logging section.
See openHAB Extensions to the standard section.
# Tutorials or other useful information
- Getting Started: Rules - Blockly (opens new window)
- How to write openHAB Blockly Libraries (opens new window)
- Extending Blockly with new openHAB commands (opens new window)
- Published Blockly Libraries (opens new window)
← Rules Transformations →
