# MQTT Binding
- EspMilightHub Binding
- HomeAssistant MQTT Components Binding
- MQTT Homie Binding
# Supported Bridges
- SystemBroker: A system configured broker cannot be changed by this binding and will be listed as read-only system-broker.
# Bridge Configuration
Reconnect parameters are:
- lwtRetain: Retain last will message. Defaults to false.
# Supported Channels
Configuration parameters are:
